Hi all,
i'm just beginning and have run into a problem right off the bat. i've just tried converting a divX movie to an MPEG1. I used tmpgenc and i followed the instructions on this site. I used the loaded template for Video CD (NTSC). The result is mixed. The sharpness of the picture is quite good, and the sound is fine. In higher motion scenes however, i find that there's a weird effect; it looks slightly jumpy, like there are frames missing or something. it really is only noticeable during scenes with lots of motion. If anyone knows what i can try to do, please enlighten me.
thanks
g
Just set the settings to high quality in Tmpgenc. It worked for me. Had the same probs as you.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 19:56 -
DTS OR AC3 to mpeg1/2 4 divx or h264
By DRINGO in forum AudioReplies: 1Last Post: 31st Dec 2011, 11:16 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 09:17 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
converting from mpeg1 to divx
By mlkwestcoast in forum Video ConversionReplies: 3Last Post: 21st Dec 2007, 11:09
