I've been sent a file ending in .iso which apparently contains a few .avi files plus some other stuff totalling about 2GB. As far as I know, an .iso is similar to a .dmg but how do I convert/unpack it? I'm running the latest version of OS X but is there any free/shareware to do this or is it really a Windows format? I thought .iso was a universal standard.
Any help for this newbie much appreciated!
Nah, it's not limited to being a Windows format only.
It's one of the standard formats of disc images.
I believe you should be able to mount it using Disk Utility, as if it were a physical CD/DVD, and be able to access the files that way. (Or using Toast, if you have it.)If cameras add ten pounds, why would people want to eat them? -
Another nice app for burning ISO (and many other formats) is Burnz which may be found here: http://thinkertons.com/burnz_features.htm
Try ToastMount too - if you get a 'no mountable file system' error the download was probably corrupted.
Thank you all for the info. I'm trying Disk Unility first but have downloaded Burnz just in case!
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
converter
By buzzyy in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2010, 23:32 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01 -
ISO M4A converter to wav
By illyad in forum AudioReplies: 4Last Post: 14th Jul 2007, 23:12 -
Need a converter that can do this...
By rindless in forum Video ConversionReplies: 2Last Post: 7th May 2007, 04:15
