I was wondering if theres a certain program that enables me to remove music in a background from a clip while people are talking as well. Both music as well as talking audio is present. I just want the music to go. Is that possible?
Hi Guardian2099,
Depending on how your audio has been recorded, it will either be easy or virtually impossible.
If the audio comprises of one track for the people talking and a seperate track for the background music then it's a simple case of deleting the track you don't want in any audio editor. Audacity is free and very good - there are others.
If the people talking and the background music are combined into one track, it'll be extremely difficult, or trick, or virtually impossible.
Think of your audio as a painting: if you first paint the picture on a canvas you can hang it on a wall, or you can paint on the wall directly just after the wall itself has been painted, where the paint will merge into one.
They will effectively look the same, but one's easy to remove and the other is a lot more difficult.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Even if the audio is still contained within one track, you can still work on the ability to remove the music.
The tool(s) you need to look for is parametric equalization, or notch audio filters.
Not all sound editting software will have these functions. So you'll have to look through the functions carefully, if listed in their specifications.
Even so, it is still trial and error.
You may not get a crystal clear seperation - but your results may be acceptable.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
Keeping Voice, Removing Background Music How?
By Teac23 in forum AudioReplies: 4Last Post: 26th Feb 2010, 06:01 -
removing background of animated gif
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 26th Oct 2008, 00:44 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 12:56 -
DVDSlideshowGUI removing background and...
By chewie8008 in forum EditingReplies: 5Last Post: 1st Jul 2007, 17:34 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 21:27
