I have pretty annoying problem with TMPEGEnc. On my PII PC it works fine but I copied it on another PIII and PIV PC where it, always when I start it, says:
"CPU setting has been reset to default because CPU might be different from last time, or new command has been supported"
It allows to continue and when I set options in environment settings and close it, on next start I get the same message and all settings I made are ignored ?!
I think some file need to be removed from directory but I don't know which one - anybody can help ?
Results 1 to 1 of 1
Firefox Won't remember setting
By DarrellS in forum ComputerReplies: 5Last Post: 18th Jul 2010, 02:25 -
TMpegEnc DVD Author won't fill a 4.7 GB DVD
By jagojon3 in forum Authoring (DVD)Replies: 12Last Post: 29th Dec 2008, 18:32 -
Help!! PC Monitor Won't Reset To Factory Settings.
By Aaron1927 in forum ComputerReplies: 1Last Post: 29th Dec 2008, 10:30 -
Fiddled with RAM settings - now my computer won't even post
By wiseant in forum ComputerReplies: 7Last Post: 2nd Feb 2008, 13:42 -
Ati AIW won't remember video resolution
By crimzind in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 16:07
