I've tried looking on the Project X user forum but it's mostly in German (?) and I can't find out the best way to stop it getting this error.
Basically, I'm trying to convert recordings from my Humax PVR that are in .TS format to Divx. I use AutoGK to convert the mpeg to Divx, but the problem is the first part, getting the .TS to mpeg with the audio staying in sync (I have tried going straight from .TS to divx in AutoGK but that has mixed results).
Any suggestions?
Thanks guys
I have the same problem when I try to process a recording which has lot's of errors in the TS/MPEG stream....
ProjectX will then crash with out of memory soon or later....
Sometimes turning off the error messages will help..
Also you can try to split up the processing of the TS/MPEG in smaller parts, maybe that will help..
See also:
Hauppauge UK: Solve a CRC error in a capture
Overclocking, memory problems??
By HotDamn! in forum ComputerReplies: 26Last Post: 29th Apr 2010, 13:05 -
Problems with my VHS/8mm/MiniDV to DVD project
By compgl in forum Capturing and VCRReplies: 6Last Post: 15th Jan 2010, 10:30 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
Memory Problems
By steve42069 in forum ComputerReplies: 5Last Post: 2nd Jan 2008, 12:10 -
Many problems with editting video project.
By bluestar88 in forum EditingReplies: 0Last Post: 3rd Jun 2007, 18:47
