I'm not sure that Divx MediaBuilder is what I want - too much.
All I want, is to run some sort of Divx Video/Menu so that I can select the video I want to play and play it.
Any ideas?
Divx/DVD players will automatically give you a list of files when you put the disk in the player.
If you have a Divx Ultra Certified player, then DivxMediaBuilder is about your only choice at the moment.
If you have a standard Divx Honme Theatre certified player, you have to use what it gives you.
If you want to play it back on a PC, you can use one of the many (and sometimes free) CD menu building applications to create a menu front end. It will only work in a PC though.Read my blog here.
How do you make a simple html file showing list of files in a folder?
By yoda313 in forum ComputerReplies: 2Last Post: 6th Mar 2010, 20:12 -
Simple DVD to DIVX with quad core support?
By jarrodl in forum DVD RippingReplies: 2Last Post: 27th Aug 2009, 16:36 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
DVD software to make simple divx data disk
By gthorley in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 13:28 -
Is there a list of supported resolutions for DivX certified DVD players?
By quitearush in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 05:26
