Hello, here's what I want to happen. A person inserts the DVD and the menu plays (I got this down so far) But I want a very simple menu. I have 4 video clips and I want all 4 to be shown on the initial menu so anyone can choose any of them and play. When the clip ends, I want it to show the menu again. I think I've made the appropriate changes but it keeps playing all the clips and only after the last clip will it return to the menu. I guess what I'm saying is. I don't need submenus like track and chapter menus. I just want everything on the main menu and after it's done playing the one clip a person chooses, then it should return right back to the main menu. Is this possible?
You're probably adding all your clips into one track. What you need to do is add your clips into separate tracks. Also, choose the option to "Display Main Menu Only."
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 14:58 -
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 08:47 -
(Picture) Tmpgenc DVD Author 3 Question
By Maikeru-sama in forum Authoring (DVD)Replies: 0Last Post: 3rd May 2008, 19:20 -
TMPGEnc DVD Author 3 Question ...
By ZaYoOoD in forum Authoring (DVD)Replies: 5Last Post: 3rd Dec 2007, 08:17 -
By newtie in forum Authoring (DVD)Replies: 1Last Post: 4th Sep 2007, 10:49
