Hi there,
I've created a DVD with some menus and music but I don't need any video footage. However, I have to include a video file for DVD Lab Pro to compile the project. So I'm looking for a blank mpeg file, a really small one. Can somebody please help me? If you can make one or already have one, please send it to smcgowan@gmail.com. Just a few seconds of black screen will do.
Cheers!
Sean
Which version of DLP are you runing? Some of the versions (other than recent DLP 2.0) have small clips in the CLIPS tab.
You could also just add a slideshow with one picture in it (delete the empty movie).
Regards,
George -
Make it yourself:
BlankClip(Width=720,Height=576,Pixel_Type="YUY2",F PS=25,Length=50)
If you haven't installed AviSynth, then do so and then create an AviSynth script file. Do it like you're creating a .txt file, but rename it BlackVideo.avs or something like that. Inside stick that one line. That's for CCE, the YUY2. If you use TMPGEnc, then change pixel type to RGB24. That'll create a 50 frame, 2 second long, PAL DVD black screen video. Adjust as necessary. You can make it only a frame or 2 if you wish. Test it out in VDub(Mod) to make sure you did it right, load it into your encoder, and create the short black-screen MPV. Takes no time at all.
http://www.avisynth.org/BlankClip
Blank CD
By Elevenius in forum Newbie / General discussionsReplies: 13Last Post: 20th Apr 2011, 02:37 -
BD- Rebuilder blank option
By asiafan in forum Video ConversionReplies: 0Last Post: 4th Apr 2011, 06:30 -
monitor went blank
By d_unbeliever in forum ComputerReplies: 6Last Post: 5th Nov 2008, 08:23 -
Blank Video
By dweezil2176 in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2007, 19:49 -
Video Is Blank
By Potenza in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 18:59
