I've been happy with AutoGK, of all the programs I've used I like it's results the best, it's not the fastest, but I like the image. I tried a Few Encodes at 720 using a Quality based encode of 80%. The Image is very close to the original. I will occasionally watch these on my Widescreen Monitor and also a Portable. Would 640 Fixth Width be a better option or is 720 a better option for a resolution close to the original?
It probably depends on your players. Leaving the video at 720x480 (720x576 PAL) will avoid any resizing which always adds (at least a little) artifacts. You would then use the codec's internal PAR setting to specify the display aspect ratio. But not all players respect that setting. Many assume square pixels for Divx/Xvid AVI files.
If your players support the PAR setting and you don't mind relying on that, then 720xwhatever will give slightly better results. My Divx/DVD player doesn't respect the PAR so I use 640xwhatever, square pixel.
DVD to MKV - Is 720p Overkill?
By THRobinson in forum DVD RippingReplies: 37Last Post: 2nd Sep 2011, 15:59 -
HELP: AviDemux - Width is not a multiple of 8
By andwan0 in forum Video ConversionReplies: 2Last Post: 27th May 2011, 07:22 -
12.0 Mbit/sec MPEG2 Capture Overkill?
By hech54 in forum Capturing and VCRReplies: 17Last Post: 24th Dec 2010, 09:20 -
tmpgenc xpress auto resize results in 708 width in 720 frame.
By davexnet in forum Video ConversionReplies: 0Last Post: 27th Jan 2010, 13:49 -
Is 13 Mbps an overkill for a bitrate?
By edong in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Dec 2009, 05:26
