I have about 7 DVD's that I only want to extract 1 or 2 chapters from each and then, batch them togther and burn onto 1 DVD. What is the easiest way to extract these chapters and burn them onto one DVD? I did try to extract the chapters with CloneDVD2 but it seems to create too large of VOB files.
DVDDecrypter....if you know the chapter number.
DVDShrink in Re-Author mode if you wanna actually SEE the chapter(s) you want to take.
Granted you will need lots of folders or subfolders to accomplish this...then they will need to be re-authored back to a burnable DVD. You will also have pauses between the chapters if you re-author again with DVDShrink. You'll need to do this trick:
https://www.videohelp.com/forum/userguides/120021.php
to make them a smooth transition....or maybe TDA can re-author smoothly as well.
easiest method to convert movies with multiple m2ts files (seamless branch)
By zero7404 in forum Blu-ray RippingReplies: 3Last Post: 22nd Aug 2011, 09:10 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Best/Easiest way to make multiple segments of a mp3 file?
By raydeneg in forum AudioReplies: 4Last Post: 7th Oct 2008, 09:47 -
Creating chapters from multiple video files in Sony DVD architect
By MTy in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 13:22 -
Easiest way to join multiple video file?
By thecalip in forum EditingReplies: 1Last Post: 29th Jul 2007, 10:52
