The programs I use and the order in which I use them are as follows, RipIt4ME > DVD Decrypter > FixVTS > DVD Shrink 3.2 > Nero 6.0.0.9 . The error I'm getting happens anywhere between halfway to about 99% of the way through burning a disk using Nero. I've uploaded the error log .txt file. Any help on this matter is greatly appreciated. Thanks in advance!
Dustin
burnerrorlog.txt
Dustin you need to edit your burn error log and remove your Nero serial # from it......
What media are you using? -
Did you always have this problem with Nero 6.0.0.9 or did it just begin? This version is pretty old and may not fully support your burner. Did you check Ahead's web site for an upgrade version?Originally Posted by objectnull
objectnull,
The media you're using (CMC MAG E01) isn't very good (nomorecoasters.com rates them as 3rd class). That's most likely your problem. The atapi error code (030C00) tends to support that conclusion. Higher quality media would likely solve your problem.
By the way, I see this was your first post. Welcome to VideoHelp. -
Also, assuming you are ripping video, you can do it with half as many steps as your current process.
Google is your Friend
Question about new type of Nero 6 burn error
By jimdagys in forum DVD RippingReplies: 13Last Post: 29th Jun 2009, 01:22 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Error when dvd shrink trys to burn thru nero automatically
By themow in forum Video ConversionReplies: 1Last Post: 13th Oct 2007, 14:12 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28
