    Oct 2003
    I had to recently upgrade to SP2, WinXP Pro.
    Now, all DIVX-encoded videos are dis-colored and messed up when playing back in mplayer10.
    Is this a common issue and is there a fix?
    MPG play back fine.
    AVI plays back fine in Divx's Player
    Using 6.3.0 I think. The latest (registered).
    USA
    Similar problems have been posted here before. It's usually a codec problem, either a conflict or a corrupt codec. If you have installed any codec packs, that would be one cause. I doubt it has anything to do with SP2, though stranger things have happened. Or it may just be Mplayer10 (WMP10?) If so, just use a different player or reinstall it.
    You can see what codecs you have installed and remove them if they are damaged with DXMan or Codec Sniper.
