Last week, the remote on my 3 month old GoVideo SDV-650 went dead. I couldn't find an exact replacement remote, so I ordered one for the JVC HR-S9800U (which the Go model is a clone of - JVC assured me it would work, and the remotes look exactly the same except for color and branding). Got it today, and it's not working. I'm guessing that the sensor is broken. Any quick fixes or do I have to get it serviced?
Thanks!
-David
Before getting it serviced I would consider buying a cheap universal remote. You can find them at discount stores for as little as $5. If it works, you would probably still want a full-featured remote, but if nothing else you'll know if it's indeed a bad sensor on the deck itself. That's pretty rare.
I have some universal remotes around the house so I could try it, but the service place does the estimate for free and I need to go there anyway to get the power switch on my TBC fixed.
Go says that since it wasn't from an authorized reseller (it was new but I scored it on eBay), that the warranty would be expired now.
RCA VCR - change language without remote?
By TrackingError in forum Newbie / General discussionsReplies: 7Last Post: 2nd Feb 2022, 12:15 -
Lost VCR remote -- do universals work?
By cinclodes in forum Newbie / General discussionsReplies: 12Last Post: 20th Sep 2010, 12:07 -
Ir Sensor with 3.5 mm jack
By themaster1 in forum ComputerReplies: 0Last Post: 6th Dec 2009, 20:25 -
Is this dust on the sensor?
By Karl Engel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Jul 2009, 10:21 -
Wii Sensor Bar
By Squid_uk in forum Off topicReplies: 5Last Post: 26th Jun 2009, 21:03
