im sorry if these has been posted in another thread but i couldn't be bothered to seach over a 100 pages I dont think my computer has a dvd burner but i can burn cd disks is there anyway i can burn my .avi movies onto 700mb cd-r disks to play on my dvd player what software do i need please help!!!!
Yes, but they have a low compatibility with most players: https://www.videohelp.com/minidvd.htm
What may be a better choice is a SVCD or the lower quality VCD. You can see information on both to the upper left. <<<<<< -
If you have a divx dvd player just burn the avi. If not then buy a divx dvd player.
You could convert to vcd,xvcd,svcd. Check under CONVERT in the menu here to the left.
If you convert to DVD-video it wont work on most players, www.videohelp.com/minidvd
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 07:28 -
HD Camcorder - Can you burn HD movies to DVD with the right software?
By xstein in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Sep 2008, 01:27 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 06:51 -
Movies on the new HD disks... why?
By Marco33 in forum Off topicReplies: 10Last Post: 24th Jun 2007, 13:34
