Hey guys,i'm new in avisynth and i need some pointers,
an actuall thing i was wandering is how can i access more than one stream in a movie when i frameserve that actual movie into vdubmod. Can i somehow show vdubmod that there are more streams there, possibly subtitles or a secondary audio stream
Another thing also, when i frameserve, the video stream comes uncompressed, thats ok, however if i want to not recompress the audio how do i do that, cause that comes uncompressed also
Can you also suggest some pages with those kind of things for programming avisynth, (i already went to www.avisynth.org but didn't found anything that i needed there)![]()
Please be as much patient and explanatory as possible, i'm really greenin this subject.
Results 1 to 14 of 14
-Good Things Come to Those Who Wait-
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I'm afraid that didn't help
, i know that site, i created my first dvd-rip with help from there, however in the currect situation there isn't any help for me there
. Any more suggestions?
E.G. BTW, what are those coordinates for??
-Good Things Come to Those Who Wait- -
Hi-
The easiest way to handle audio is not to. If it's in an AVI you're reencoding, remove the audio and keep it on the side. If it's separate, keep it that way until after the video encoding is complete. If it needs to be converted (AC3 to MP3 for example), do it separately and remux it into the video after both are complete.
I didn't understand what you wanted to know about the subs. If you have them in IDX/SUB form, and you want to "burn" them into the video, then the VSFilter and a VobSub line in the script will get the job done. If they're in certain text file sub formats (SRT or SSA, for example), the VSFilter and the TextSub command will get the job done. If you just want to mux external or separate subs, do it afterwards.
If I've misunderstood, let me (us) know. -
That i thought as my first option, however the audio is in a very crappy format and i want it to be compatible with most standalone players, so i thought to reencode the audio through vdubmod together with the video and not externally to force it sustain timevalues,. Unfortunatelly that file has 2 audio streams and the second is not visible when i frameserve it. Do you see my prob. now? I use this script : DirectShowSource(fps=23.976,"VideoFileHere.avi") then load it into vdubmod. I know it's a very basic simple script but as i already saied i'm a beginer.
Btw, believe me when i say that if the audio was an mp3 or ac3 that post wouldn't be here in the first place. Basically i don't know what format it is, thought my system decodes it and on the other side gspot speaks of unknown codec/mime.
You know, if there is a way to remux the crapy audio after i recompressed it externally and somehow fix it's time values it's the same a good a solution for me, prob. is that i don't know how.
I used vdubmod to extract it and wavepad to recode it into mp3, then remuxed it with the video with vdub again. About 5sec desynch occured which gets more localized in the middle of the file and less in the tips. If i putt the option for changing frame durations so it matches the audio i can't see a pattern for the desynch at all.
Forget what i said about the subtitle, it's was my mistake.
Best for last i guess. Vdub doesn't open the file directly, it has to be frameserver to do so. Confused so far?? I am!!! Gspot picks up DivX50 video and "guess what!" unknown audio.
I don't know who created it but i't the only format i could find.
Good luck, i've just run out.
Hi-
You said you want it reencoded for compatibility with most standalones. To me that means DVD, yet you're only talking about VDubMod. You haven't given us the source format or container (and evidently you don't know what the audio is), nor your intended destination container (AVI?). I know less than I knew at the beginning, so I'll retire with the hope that someone steps in to help you. Good luck. -
There ARE standalonee players that play avi and mpeg4/divx/xvid you know. In anycase prob. solved, don't worry anymore, cya and thanks
@ Jo The Veteran: "E.G. BTW, what are those coordinates for?? "
ICBM = InterContinantal Ballistic Missles
coordinates = geographical coordinates of the home of SLK001
I assume.
Besides this I also have a similar question about Avisynth :
I want to convert a recording from a satellite transmission which has an AVC/H.264-video and an AC3-audio stream using Avisynth by feeding both streams to VirtualDubMod with which I only want to convert the video stream and at the same time just copy the AC3-audio stream to the converted video. So far only the video is fed to VirtualDubMod using an Avisynth-script (using Directshowsource) while no audio is received by VirtualDubMod.
Is it possible using certain script commands or plugins to feed both streams to VirtualDubMod??
CU
Schmendrick -
vid=directshowsource("c:\your video")
aud=nicAC3source("C:\your.AC3")
audiodub(vid,aud)
Also, coordinates are not my house, but they are close. Like horseshoes and hand grenades, atomic bombs only have to be close.ICBM target coordinates:
Thanks for the help and the clarification about the coordinates. I was just guessing because of the precision of giving the coordinates in 1/100th of a degree second which I think is equivalent to about one foot or 30 centimetres.
For using "nicAC3source" I assume you first have to load LoadPlugin("NicAudio.dll") into the Avisynth-script.
Schmendrick -
O.K. I was not aware that it will auto-load from the plugin-directory.
Thanks!
New AVISynth UI
By tin2tin in forum Latest Video NewsReplies: 23Last Post: 19th Jan 2012, 02:53 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 05:36 -
Using avisynth
By bsuska in forum Video ConversionReplies: 8Last Post: 16th Jul 2009, 09:32 -
AVIsynth help!
By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 04:35 -
Avisynth 3.0
By nbi in forum LinuxReplies: 1Last Post: 30th Oct 2007, 17:50
i'm new in
in this subject.
