Hello everybody,
Please help with DVDRemake.
I’d like to create a backup of a DVD movie without menu (just the movie) and without subtitles and with English audio only.
I have created a backup and deleted from the backup all files but VOBs and created new IFO with IfoEdit.
Then in DVDRemake, I deleted all audio tracks but English in Main Video Title Set 1 (there is only this one, nothing else) and disabled all SubPicture Tracks. After that, I have exported the DVD.
When I burnt the edited movie onto DVD-RW and tried to play it back on my standalone, it just starts showing “Columbia Pictures” and then stops and does not go any further.
What did I do wrong?
Going overkill with tools on such a simple task.
Easiest way to achieve the same end reliably is to open the disc in DVD Shrink, hit the Re-Author button, drag just the main title to the lefthand pane, untick an extra streams you don't want, then hit Backup. Much easier than what you are putting yourself through.Read my blog here.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 18:57 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 14:33 -
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 11:30
