I'm using WinDV as DV 'capture' with very good results to transfer the Video from my ADVC 300. But now I want to use this converter for timed recording. As WinDV hasn't that feature, I'm looking for a different solution. I downloaded the AvsTVBox, which has all the features I want, but the results are not acceptable:
- Audio is only 32KHz (despite of the fact, that the ADVC is set to 48KHz)
- Video is always captured to PAL resolution (despite is set NTSC and the AvsTVBox Configuration says so, but the resulting AVI is PAL)
- no choice of resulting AVI format (I want type 2)
Any way to time control WinDV from the outside, or any other,better DV PVR?
Results 1 to 12 of 12
Do you want scheduled recordings or just timed recordings? DVapp can or I believe Scenalyzerlive can do timed. WinDV can also with a add-on timer program. I'll see if I can find a link to the timer.
If you are asking about scheduling a recording, I haven't seen any program that can do that, but there is likely one out there someone knows about.
EDIT: You can set a timer in WinDV this way, a little crude, though:
Max AVI size (frames)... NTSC framerate.. That's 30 frames per second x 60 seconds per minute = 1,800 frames per minute x 60 minutes per hour = 108,000 frames per hour.
Get out a calculator.
I'm still looking for the timer program. -
WinDV can be used for scheduled recording by building a bat file with the command line option and then executing the bat using Windows Scheduler.
Buy My Books -
That's sound interesting. Which option can I used (or are they in the Help file).Originally Posted by gadgetguy
What I really want is a scheduled recording (but timed would do for the time being).
I don't like DVApp very much, because under certain conditions it likes to drop frames. Therefore I'd favourite any WinDV solution.
I tried and see the option:
capture [-exit] [timespan] filename
does this mean: capture starting from now for <timespan> time to file <filename> and then eventually exit?
This would sufficient, starting it with windows scheduler and let it capture until the programmed end.
Anyway to do an automatic shutdown after that? -
I think WinDV will create a new file, whenever max size is reached in the current capturing. Thanks anyway and please try to find the timer program.Originally Posted by redwudz
That will start WinDV in capture mode, capture for 1 hour and 2 minutes and save the file to the g drive in the video folder using the name prefix OneHour plus whatever parameters you have set. -exit means it will close when done recording.WinDV capture -exit 1:02:00 g:\video\OneHour
Put that line into a batch file and test it.
Then use Scheduled Tasks in the control panel to schedule it's execution.
I should mention that in my experience Windows Scheduler is not the most reliable, but it does work most of the time."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Sorry, not having any luck finding the WinDV add-on for timing. That was a year or two ago. I believe it used the same method as gadgetguy is describing, but it seemed to be easier to set up. Still looking, though.
I ran across a couple of other methods and programs. One is the new version of Virtualdub that says it can 'capture' DV, and you can set the 'stop capture' when a certain amount of time is elapsed. I need to try my ADVC-100 with it when I get the chance. (I use VD for my DV editing and filtering, then frameserve the output to TMPGEnc encoder. I convert the audio to AC3 with ffmpeggui. It might make the process simpler for me.)
The other is a somewhat unknown Japanese capture program that has a timer and is reputed to work with DV sources. Only for the experimenter, but it sounded interesting: CapDVHS http://www.yamabe.org/softbody.html#CapDVHS (Japanese but there's a
button for the English download with a readme included in the zip) -
I tried VD, but also problem with the Audio S/R: captures to 32KHz only.
If I'm not wrong the latest versions of iuVCR capture DV footage too, from the firewire port.
I asked the programmer once if it would work for scheduling with a ADVC 100 and he couldn't answer, as he does not have a ADVC card to test.
I asked someone here in the forum to test it, I don't remember who, and the guy couldn't do it.
Maybe you can try it.
I'd like to have this feature too. That's the only reason I didn't buy an ADVC 100 or ADS Pyro yet. I need scheduling. -
I should also mention that the bat file should be in the same folder with WinDV.
Buy My Books
Capture Software for Hauppauge HD-PVR
By DarrellS in forum Capturing and VCRReplies: 41Last Post: 26th May 2013, 20:24 -
Hauppauge HD PVR (Capture PC gameplay)
By TommyGun in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2010, 10:50 -
PVR Capture to MKV
By He11breed in forum Video ConversionReplies: 7Last Post: 2nd Sep 2009, 01:05 -
PVR-250 and Capture Software
By statman24 in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2008, 14:38 -
PVR capture
By boots in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2007, 22:57
