I have a movie on my hard drive (NO WAREZ), that I want on a DVD. I have Nero &.2 Ultra. I have tried recode, Make my own DVD, etc. but cannot get anything to playon my living room dvd player.. and help
It could be your player - many older players cannot read burned DVDs
It could be media incompatibility
It could be your drive.
You have not provided enough info for anyone to try to help you. -
Okay, thanks.... let me try and elaborate a little. The move is downloaded but paid for and not copyrithted. The program I am attempting to use to make the DVD is the new Nero 7.2 Ultra addition, and the DVD player is a brand new Panasonic that says it reads and writes DVD-R, DVD+R, DVD -RW, DVD-RW, etc.
What else can i give you. Please... not trying to be smart, I feel really dumb.
Thanks for any help -
Are you able to play the DVD on your computer? Try VLC if you don't have a program like PowerDVD installed.
I would first suspect the DVD media. Try a different brand. That's one of the easiest things to change and the most common source of that type of problem. You can look to the left under 'DVD Writers' for your burner and see what is suggested. Also check 'DVD Players' for your player and see what is suggested for it also. Just about every burner or player has at least one brand or type of media that's incompatible with them.
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 11:31 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
Nero 6, mpeg4 & dvd-plug in
By dll in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2007, 11:05 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 22:36
