I hope this is the correct place for this question. I am going to copy all my 8mm analog tapes and dv tapes to dvd with my stand alone dvd recorder to preserve them. I am too lazy to get around editing all of them right now.
I want to be able to go back and edit them later. How do I do this and with what program to take them from dvd to avi?
Depending on the type of editing you need to do, you will be better off, in most cases, using an mpeg editor and not converting your video to avi at all. Unless you convert to either uncompressed, or lossless compression, you will incur some degree of quality loss.
If you edit needs are simple - cuts, a simple fade here and there, and not colour correction and effects work - look at the Womble mpeg tools or VideoRedo. You can edit the material that you have encoded with no quality change in most instances.
If quality is a concern, and you have more extreme editing needs, then get a firewire card and transfer dierctly to your PC and avoid the mpeg2 stage. Mpeg2 is a poor choice for editing.Read my blog here.
Will TMPGenc dvd author work also? If taking it back to AVI I would choose lossless uncompressed for quality and I understand size would be quite large. I usally work with uncompressed AVI.
Decent DVD recorder that plays AVI (DivX & XviD MPEG-4) w/HDMI out?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Feb 2012, 19:20 -
NTSC avi does not forward when played on the DVD recorder...
By FatBoy123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Jun 2010, 14:02 -
avi to dvd recorder
By devdev in forum Capturing and VCRReplies: 6Last Post: 30th Jun 2009, 15:23 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:55
