Results 1 to 15 of 15
    Aug 2006
    Hello Everone
    I have a question about HDTV, If I have a unit which picks up SDTV but not HDTV and the OTA show is in HDTV will I still get the show in SDTV? Do they broadcast both HDTV and SDTV at the same time?
    Thank You
    rdel
  2. Preservationist davideck's Avatar
    Feb 2003
    USA
    Many do but some don't. Some HDTV channels do not have SDTV equivalents. PBS, for example.
    Life is better when you focus on the signals instead of the noise.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Hello Everone
    Thank You
    rdel
    Yes they broadcast on separate transmitters on different frequencies. Regular analog TV sets pick up the traditional channels (NTSC in the USA). These channels will be turned off in ~2009.
    Each station now has a second DTV station that needs a DTV tuner to receive. The DTV station can carry either the SDTV or HDTV version of the program or both since DTV can carry multiple "subchannels". The subchannels can also carry completely different programming like the PBS HD channel which is fed from a national satellite feed.
    A typical major network station looks like this.*
    NBC4 - traditional analog NTSC broadcast
    NBCDT 4.1 - SD or HD version of the network broadcast
    NBCDT 4.2 - Weather or News
    A typical PBS station looks like this
    PBS9 - traditional locally programmed PBS NTSC channel
    PBSDT 9.1 - PBS HD or SD widescreen channel off the satellite (same nationwide)
    PBSDT 9.2 - second SD local program schedule
    PBSDT 9.3 - third local channel (daytime)
    PBSDT 9.4 - forth local channel (daytime)
    The third and forth channels often support the local schools When they are on the air, the HD n.1 channel must be SD since bitrate is shared.
    The new Digital TV sets, or older analog sets with an external DTV tuner will receive all the DTV stations. If the TV is only able to display in SD resolutions, HD broadcasts are downscaled in the tuner to the display resolution of that TV.
    * In ~2009 the analog channels will be turned off. When that happens, a typical Network station is expected to look like this, although each station has options for resolution, aspect ratios and use of subchannels.
    NBCDT 4.1 - HD or SD 16:9 version of the network broadcast
    NBCDT 4.2 - SD 4:3 version of the network broadcast.
    If you had a SD 4:3 TV, the first channel would always show in letterbox. The second channel would always show full screen.
    Aug 2006
    Thank You edDV and davideck
    The reason why I was asking is I'm into FTA (free to air) and I want to get the digital OTA channels to go along with my setup. I'm looking into getting a Dreambox 7025 which will do FTA, OTA and has a PVR but won't do HDTV (yet) My TV isn't HDTV so I really don't need the HDTV setup yet.
    I think I'll start a new post and see if anyone has a dreambox.
    rdel
    http://www.dream-multimedia-tv.de/english/products_dm7025.php
    http://www.dream-multimedia-tv.de/english/products_dm7025_technical.php
    Mar 2003
    Canada
    That box you posted is for DVB, which is the european DTV broadcast standard. WHat you're looking for is a ATSC tuner.
  6. Preservationist davideck's Avatar
    Feb 2003
    USA
    CC has an ATSC tuner with HDMI, HD component, and SDTV outputs. No QAM. OTA only.
  7. Member edDV's Avatar
    Mar 2004
    Here's a list of current OTA and DBS turners
    http://www.avsforum.com/avs-vb/showthread.php?t=179095
    Aug 2006
    Thank you for all the replys, I found a phillips tuner that may work and its plug and play.
    Quote from data sheet
    The Philips plug-n-play tuner is an integrated, so-called 2-can product that offers a unique dual RF input, supporting NTSC, ATSC and QAM reception. It consists of the PA1232D and the TUV1236U modules. All RF tuning for analog, digital and out-of-band signaling is self-contained in these modules. The PA1232D is an “input module” that offers dual RF input with an electronic switch that meets stringent FCC requirements for isolation. One input is intended for off-air terrestrial reception and the other is intended for cable reception.
    here is the link
    http://rfdesign.com/mag/radio_philips_launches_unique/index.html
    Please post any input you may have, I'm new to OTA and trying to get the best of both worlds in one.
    Thank You Everyone
    rdel
    ps I wrote to the dreambox company today for their input and am still waiting for their reply, will keep you posted.
  9. Banned
    Freedonia
    rdel - OTA is not as great as you might think. It varies from location to location. I live within 15 miles of almost every single HD transmitter in my city. I think one is 16 miles from me and the others are between 12-15 miles. I was never able to get in NBC no matter what I did. Only Fox came in great every time and then disturbingly I stopped getting consistently good feeds from Fox. It would be great for 20 minutes and then crap for the next 10. It got real old. I finally just paid the cable company to get HD with a cable box and life is good again.
    To be fair, I do not have an outdoor antenna, just an indoor one. Be prepared that you may need to put an antenna on your roof to get reliable OTA signals. The further you live away from the broadcast towers, the more problems you will likely have.
  10. Banned
    Feb 2005
    USA
    Geography plays a big part in this too. You could be five miles from the broadcast tower and yet have a big ol' mound of a mountain between you.
    Aug 2006
    Thanks jman98 and rof for the input, I'm around new orleans and I know were having problems with some of the stations. I guess I'll just take my time with OTA and stick with FTA awhile.
    I'll keep you posted on what I find out about the Dreambox.
    Thanks again
    rdel
    Aug 2006
    Just wondering, what is CC???
    rdel
  13. Preservationist davideck's Avatar
    Feb 2003
    USA
    Circuit City - Pro Brand HDTV Receiver (HD3150PLUS)
  14. Member edDV's Avatar
    Mar 2004
    Review this forum for others DTV OTA experiences around the New Orleans market. Usually the signals are strong in the larger cities. Small towns usually run at minimal power until 2009. Ask them which tuner and antenna you should use. Don't trust retail sales people. They don't know much.
    http://www.avsforum.com/avs-vb/showthread.php?t=357741&page=20&pp=30
  15. Member zzyzzx's Avatar
    Baltimore, MD USA
    Or just a better antenna. The outdoor antennas work pretty good when mounted indoors. It does practically take up your whole living room ceiling, but it works great and is a conversation piece.
