Hi
Not sure how to explain what i need (my bad english)
But i'm searching for a program where you can load a Mpeg 1 file into.
Then on a timeline set markers where the previous scene ended and the next one starts.
And the program should export all the scene's separetely.
So load moviefile.mpg
and export
moviescene1.mpg / moviescene2.mpg / moviescene3.mpg etc..
We use a program now where we can export the scene's one by one but i would like a program which exports all the scene's at once..
If it even exists
primanocte ,
Hi. You can use the Trim Manager in MPEG Video Wizard to export these scenes automatically.
Trimming is the most basic and frequently used editing operation. The simplest form of trimming is selecting a clip segment and removing all parts outside of the segment, without changing any of the original content and compression parameters. This form of trimming can be done quite easily in the Input Monitor in MPEG Video Wizard.
The operation step below:
1) Open your MPEG file into Input Monitor
2) Select the 'Trim Manager / Add' from the monitor menu (right mouse click) to open the Trim Manager Window.
3) Using the 'Mark In' and 'Mark Out' to select your scenes.
4) Select the 'Trim Add' from the menu (right mouse click) to add this scene into Trim Manager.
5) Repeat the step 3 and step 4 above until adding all the scenes into Trim Manager.
6) Click the 'Start All' in 'Trim Manager' to exporting all the scenes automatically.
Wish to help you.
Womble Mpeg Editor help, please. Thanks.
By seymoria in forum EditingReplies: 9Last Post: 20th Sep 2013, 06:20 -
HDV timeline footage to SD (16:9 or 4:3?) NTSC dvd spec MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 19Last Post: 25th Mar 2011, 06:10 -
FCP6-No longer possible to export Mpeg-2 from timeline?
By stretchweider in forum MacReplies: 4Last Post: 15th Jul 2008, 18:33 -
Sophisticated MPEG-2 Editor
By neumannu47 in forum EditingReplies: 12Last Post: 1st Jun 2008, 01:33 -
MPEG 4 editor
By spikey-k in forum EditingReplies: 2Last Post: 23rd Jul 2007, 05:39
