I have a bunch of divx avi files. I need to write them to a dvd with a menu which i can use to choose the divx file. help me how to do make a dvd with this.
Thiyagu
You can use ConvertXtoDVD to convert them to a DVd compliant structure (effectively create a DVD), but I wouldn't put more than 2 hours on a disc.
If you have one of the rare Divx Ultra certified players, you can look at DivxMediaBuilder.
If you have just a PC, look at one of the many CD menu programs for creating autostart menus.
If you have just a normal, Divx Home Theatre certified player, then you are stuck with the menu it gives you.Read my blog here.
Convert VOB files to Divx with DVD menu
By xtof in forum Video ConversionReplies: 1Last Post: 1st Mar 2011, 15:29 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 14:04 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 08:57 -
Multiple video files to 1 DVD w/ menu
By vanquish42 in forum Authoring (DVD)Replies: 16Last Post: 3rd Apr 2008, 18:18 -
Multiple Divx/Xvid files on DVD w/ menus and selectable subs?
By louv68 in forum DVD RippingReplies: 4Last Post: 18th Jul 2007, 08:01
