I have a kw-tv878SEC card, (says "Security TV card" on box) which worked fine on my last PC running Win XP. I have recently built an AMD64 based PC running XP64bit and the capture card is giving me a serious head ache. The drivers from the Setup CD wont work and the website doesn't have any sol'ns either. Any help? Thanks in advance.
I had run into similar problems with my other PCI devices, but fortunately those manufacturers' websites had XP64 drivers available for download.
Problem Solved...sort of
I recieved a reply from Kworld Customer Service. It was a short, polite message letting me know that "Thank you for your email. Actually, we don't have driver supported XP 64 bit at this moment. But we will report it to our RD and we believe we will have it as soon as we can. "
So if anybody else was having similar issues, there's your answer. Guess I'll put the card in another machine until I can get the drivers. -
Do you still have the CD of kw-tv878SEC card, (says "Security TV card" on box). I also have one but I lose the CD. I try to download it in internet but can't found it. If you have it, I'm very very please you send it to me. My email is rayhellohello@yahoo.com.hk
hehe. 3 year old post from someone who hasn't been back since. and you want a personal email of a cd iso. email is limited to under 10mb, it's not going to happen either way.
These free drivers might work for your card.
http://btwincap.sourceforge.net/ -
video_magic, thanks a lot. I go to website of Kworld and download a program which not for 878 but it's an analogue capture and it works! Thanks.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 09:59 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
