Hello everyone.
I have a movie with idx/sub files subtitles, I want to know if there is a way to change the position of the subtitles in the idx file.
I know it can be done by changing to srt or ssa formats, but I want to know if there is something that can be modified or added to the idx file to change the subtitles position.
Thanks in advance for your help.
Hi-
As I found out in a similar discussion yesterday, changing the position in the IDX isn't recognized when playing back in a standalone. However, it does work for computer playback, or for encoding the subs into the video.
Open the IDX in VobSub Configure. It comes with the VobSub package. To raise them, adjust the Y-Axis in a negative direction. Another way is to open the IDX in Notepad and find this line:
To raise them on the screen, do this (as an example):# Origin, relative to the upper-left corner, can be overloaded by aligment
org: 0, 0
I hope that's what you meant by "position". If not, please explain further.# Origin, relative to the upper-left corner, can be overloaded by aligment
org: 0, -75 -
Hi-
Question: by "Computer playback" you mean playing it on BSPlayer, WMP, VLC, etc?
Yes.
I think by standalone you mean a consumer dvd player, right?
Yes.
It works for me. I was just testing using Media Player Classic and Windows Media Player. I changed the number to different figures, and the subs played at different heights on the screen. Are you using DirectVobSub to play the subs? That is, does the green arrow appear in the Sys Tray when you start the AVI? It could be, although I don't know for sure, that you may be playing subs through the players' own subtitle engines or something else (ffdshow?), rather than through DirectVobSub, and they aren't using the IDX parameters. -
Yes, it worked in Windows Media Player.
Last question: is it possible to make the same work on BSPlayer? I looked around, the only option referring to VobSub I found is this. And this on filter management.
When playing the avi on BSPlayer, the DivX settings mannager appears on the System Tray. The idx/sub subtitles display well, but modifying the coordinates on the idx file doesn't work in BSPlayer. -
I'm sorry but I may not be able to help with that one. Although BSPlayer is a very good player, it's been a while since I used it, and I'm a little foggy on the details. I do remember that it can play subs on its own. It has it's own subtitle engine. Whenever I played subs with it, I got double subs, one being played by BSPlayer and the other by DirectVobSub. I right-clicked the video and turned off one of them. But I forget which subs then played. I'm pretty sure it was the DirectVobSub ones. Since I don't plan on reinstalling it to diagnose your problem, may I suggest that you try Media Player Classic which reads the info in the IDX correctly. It's a very good player, and will play everything correctly without any tweaking.
That pic you provided shows you do have DirectVobSub installed (and registered, I presume), so you should be able to get it to work using BSPlayer.
This is more up celtic_druid's alley than mine. -
Media Player Classic works great. I'll go with that.
Thanks for your help.
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 04:23 -
Automate the conversion of subtitles from sup or sub+idx to srt
By mr.duck in forum SubtitleReplies: 4Last Post: 8th Oct 2010, 11:15 -
How to make idx/sub subtitles
By GoldenDragon in forum SubtitleReplies: 5Last Post: 1st Sep 2010, 09:40 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10 -
To many IDX & SUB subtitles from DVD...
By locousa in forum SubtitleReplies: 8Last Post: 11th Aug 2008, 08:02
