Hello everybody,
I have a backup of a DVD movie (7 VOB files). When I play back VOB files I have English sound in 5 VOBs on channel 1 and in 2 VOBs on channel 3 (Audio 1 and Audio 3).
How should I handle such files in order to burn the movie on DVD and to have English on one channel?
Thank you!
Are you sure it is the same title all the way through ?
Try loading it into DVD Shrink to see the actual structure. Shrink also has a stream remapping feature which might help. Otherwise something like PCGEdit might be needed.Read my blog here.
Thank you for your response.
I have double checked. It is the same title.
I followed your advice and used DVDShrink to make a movie and after that burnt it on DVD-9 with Nero.
English on one channel and I can choose it from the langauge settings with the remote. While the movie was on my HD yet, I set English as default with IfoEdit and it has worked but it does not work on my standalone but it is OK.
mp4box and non-English subtitle
By ngngokkiu in forum SubtitleReplies: 1Last Post: 10th Mar 2012, 04:37 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
How do I reduce sound channels from 5 to 2 on my xvid file?
By aqueousdan in forum AudioReplies: 6Last Post: 5th Jun 2010, 13:22 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 09:41 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 16:07
