I have some .dv mac files. Should I convert them to .mov (DV compression) so I can import them into Premiere (I'll be exporting MPEG2 with CCE)? Or should I convert the .dv to MPEG2 with CCE first, import the MPEG2 files into Premiere and then export them from Premiere with CCE again? Not sure how to get the best quality CCE MPEG2 from my .dv source after editing in Premiere.Thanks
Results 1 to 17 of 17
import them as .dv mac files
you could try changing the extension to .AVI, ive imported them before
GREAT idea, but no dice. What process would you advise? If I encode with CCE first, which does accept the .dv master file, and then reencode my edited MPEG in a Premiere export, might it just copy the compression source like VirtualDubMod? The Quicktime Pro conversion to .mov (DV) took some time so I feel like I'm loosing quality. Fewest or neatest recompressions are preferred, obviously. Thanks again.Originally Posted by BJ_M
you would be losing tonnes of quality converting to mpeg first .... dont do it ....
QT conversion to DV.mov output is also losing some quality as QT will recompress it - and not just parse it .... stupid qt .... but it is a better option ....
why not just export it from apple as avi in the first place ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I don't have a mac, just the .dv files on a disc. I want to keep the quality. Thanks for your consideration. 8)
recompress
Focus Enhancements Firestore DV File Converter will convert it with out recompression ...
so can DV Converter v2.3 http://www.baobab.net/softcs.htm#dv
i believe MPlayer (Mencoder) can also do it - as well as QT pro of course ..
sony vegas might also (try the trial version) -
none of the above will recompress the source ,,"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'll try some of your suggestions. Sorry about the repost, I thought some experts might only be active in DVD.
kippard
Vegas (PC) takes .dv mac files. Now we'll see if I can export through CCE as with Premiere Pro. Still want to check out Mencoder, if it parses and doesn't recompress. Thanks again.
Could you tell me how to do this? I can't sort it out.Originally Posted by BJ_M
Again thanks. -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
Suggestions? Thanks
