I've used Pinnacle to create a video with a top menu, scenes and chapter points. I saved it in Pinnacle as an AVI file and would like to reauthor as a DVD. How do I create a DVD with the original Top Menu, scenes and chapter points from the Pinnacle compressed AVI?
(had to move as a compressed AVI to a computer with a DVD recorder).
You can't. You would have to output a compliant DVD structure, as by compressing everything to an avi, you have lost all the actual menu information. If you have output mutliple avi files (the main movie, the menu background etc) then you might be able to use all of these to create a DVD if you have authoring software on the PC with the burner. Otherwise, move the burner to the PC with Pinnacle and author correctly.
Read my blog here.
+1 audio steam to the DVD with original menu.
By kurochocho in forum Authoring (DVD)Replies: 0Last Post: 12th Jul 2011, 11:48 -
Original DVD Menu
By cavusozkan in forum Authoring (DVD)Replies: 8Last Post: 17th Feb 2010, 22:54 -
Keep original DVD menu, add new movie file
By Booklet in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2009, 17:21 -
how to keep original menu and not re-encode files by dvd authoring
By deejay.2001 in forum Authoring (DVD)Replies: 8Last Post: 1st Sep 2008, 03:08 -
Add a new audio stream to dvd and keep the original menu
By CostasGR in forum Authoring (DVD)Replies: 2Last Post: 15th May 2007, 05:33
