I'm about to buy a second PC that will be an "editing only" pc and I would like to use my current PC for compositing and effects.
So my question is thus; Will a gigabit ethernet connection between the two pc's (no router/switch in between) be fast enough to allow me to access the editing pc's hard drive from the compositing pc as though it were a regular internal hard drive? i.e. without any lag in response time.
Yes. At GbE speeds, the hard disk on either end is likely to be a more limiting factor than network speed, so accessing a network drive will be about as fast as accessing an internal one.
Throughput maybe, but your access times are going to suffer. The only thing I used my GbE network for was transferring files from my two workstations for editing or encoding over the network because then your processing speed is actually the bottleneck.
I tried editing a remote file with Premiere and it did not like me for it at all. It took much longer to jog the file around.
However if you're using any sort of nested array or FC drives then your GbE network is still the bottleneck.FB-DIMM are the real cause of global warming -
just a tip... map a network drive to the folders you wish to access. mapped drives respond quicker than simply accessing them from 'network places'.
I am just a worthless liar,
I am just an imbecil -
And it makes things a lot simpler.
What program do you use for accessing newsgroups?
By johns0 in forum PollsReplies: 15Last Post: 24th Jul 2010, 12:06 -
Looking for a LAN Media Player for ISOs with DVR capability
By chulew in forum Media Center PC / MediaCentersReplies: 0Last Post: 24th May 2010, 13:07 -
Accessing an 8 Year Old CD-R
By Soopafresh in forum MediaReplies: 1Last Post: 10th Feb 2010, 08:13 -
Problems accessing certain websites
By wan2no in forum ComputerReplies: 7Last Post: 1st Jun 2008, 10:41 -
Difficulty Accessing Video Help
By usually_quiet in forum FeedbackReplies: 7Last Post: 14th Apr 2008, 17:11
