Can someone tell me how to see incomplete avi or divx files?
Any software?
Thanks a lot...![]()
Divx Player (that comes with the Divx codec). Or try using DivFix to rebuild the keyframe index.
I also use VLC. It works well with viewing partial downloads if your download program has a preview feature. It also works with most any video formats without having to install additional codecs.
You can also sometimes put them into VirtualDub and fix them so they will play, then salvage the usable part of the file.
Any Way To UnRar Incomplete Files?
By skirk in forum ComputerReplies: 4Last Post: 15th Feb 2012, 17:18 -
avi to ipod conversion incomplete
By millieflower in forum Video ConversionReplies: 1Last Post: 25th Jan 2009, 00:08 -
Incomplete Encoding? (RMVB to AVI)
By Takius in forum ffmpegX general discussionReplies: 3Last Post: 25th Dec 2008, 02:06 -
ProjectX Generate Incomplete Files
By normanking in forum DVB / IPTVReplies: 4Last Post: 3rd Dec 2008, 17:31 -
how to view .divx incomplete video
By nargisform in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2008, 14:22
