when i use svcd2dvd it wont let me change my settings it comes up with this error message:
ee the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: QueryInterface for interface NEROLib.INero5 failed.
at NEROLib.NeroClass.GetDrives(NERO_MEDIA_TYPE lVal)
at x3284ccece41ee22b.x753c147d603aabe6.xf224c03044d5d 4e1()
at x3284ccece41ee22b.x753c147d603aabe6.get_xaa807afed 8dd2568()
at x3284ccece41ee22b.x58ff75059d7bf794..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.x6341f549d2d05 feb(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.DotNetBarManager.IN(BaseIt em 5DO)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.Bar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.1.2308.33338
Win32 Version: 2.1.2308.33338
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 5.6.0.0
Win32 Version: 5.6.1.9
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
Interop.NEROLib
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.NEROLib.DLL
DllRegServerAssemblyeebe054cf6bd4330b667ab5c9747c8 24
Assembly Version: 0.0.0.0
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
You might read this and see if it applies:
https://forum.videohelp.com/viewtopic.php?t=298887Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Render Settings Nero 11
By Firelance in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2012, 05:01 -
Can't access my router's web page to change some settings
By Enowil in forum ComputerReplies: 17Last Post: 10th Jan 2012, 07:57 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 16:30 -
Can I change the filename order in Nero?
By DVantrease in forum Authoring (DVD)Replies: 11Last Post: 5th Oct 2008, 13:30 -
change dimensions easily, and encoder settings?
By ChillBill in forum EditingReplies: 3Last Post: 12th Aug 2007, 14:49
