a 2 part question I would very much appreciate help on.
I have downloaded a large wmv file it was 100 Mb got message download complete and it isnt as there are only 80 Mb or so. I can play the file but it wont go into a video editor such as nero as it says file needs to be indexed. Please tell me how to do this.
b the site i download from used to allow download managers from which i could restart or continue an interrupted download now it doesnt and it seems my machine (running windows XP) stops in save as well short of the full download. How may i prevent this and ensurei get all the download
help most appreciated thanks
joe
Windows download supports resume for partially downloaded files, but only if the site supplying the files supports resume. Sounds like the site you are using is preventing it from functioning.
Google is your Friend -
thats a cool picture thank you for your reply, however whats happening as per above is machine is telling me it is complete when its not, so asf can now index it (thanks to the answer above) and i can play the file or i can edit it. However i9f i want to complete the download the only way is to clear the IE temp cache and start all over again
thank you
joe
Any Way To UnRar Incomplete Files?
By skirk in forum ComputerReplies: 4Last Post: 15th Feb 2012, 17:18 -
Authoring from downloaded video files ...
By deepcut in forum Authoring (DVD)Replies: 13Last Post: 28th Nov 2011, 07:07 -
Improve Quality of Downloaded FLV files..
By Deter in forum EditingReplies: 4Last Post: 9th Jul 2010, 22:25 -
Protect Video Files From Being Downloaded (FLV)
By foochuck in forum Video Streaming DownloadingReplies: 1Last Post: 12th Oct 2009, 15:06 -
ProjectX Generate Incomplete Files
By normanking in forum DVB / IPTVReplies: 4Last Post: 3rd Dec 2008, 17:31
