hi ..
i have 21 xvids i would like to put onto dvd
i was wondering what would be the best process
the xvid files are about 25min long each and they are on average 120mb
any quick and easy ideas?
Results 1 to 13 of 13
convertx2dvd
...but don't try putting all 21 videos (~10 hours) on one disc - 2 hours max/DVD is my recommendation. In VCD quality, you can squeeze 6-7 hours on a single layer disc, but VCD quality is not what you expect from a DVD.
/Mats -
I'm surprised at such a low bitrate for that resolution. I'd have to agree with Mats on the running time. Perhaps with DivxtoDVD (the freeware version) you might get 6 to a disc, because of the way the encoder in that version works. But don't expect DVD or even near DVD quality from the exercise.
If you had a Divx certified player you could put all of them on one disc and be done with.Read my blog here.
i dont mind spreading them out on to multiple DVD's
if that would improve the quality?
how many per dvd would you think would be good quality? -
Generally, using 3-4 times the XviD bitrate when reencoding to DVD specs mpg does the source full justice. That would suggest 1500-1600 kbps, but I wouldn't go lower than twice that for full DVD res - ideally 5, no more than 6 episodes/single layer DVD IMO.
/Mats -
oh i c... so can you suggest a program that i can do that?
does nero have that ability to do that? -
Since the lowish quality of the original files, I would use TMPGEnc Xpress to convert them to Mpeg-2 and DVDLab to author them on 2 or 3 DVDs.
In DLP you can either
- Set chapter manually using the time line
- set chapter automatically using scene detection
- set chapters automatically using time intervals
I would consider DivxtoDVD as another alternative, although you would not get menus. It will put 6 to a disc, and TDA can then import these so you can create a menu and add chapters. Might be simpler than DLP.Read my blog here.
