As title, I have an AVI file: 576x320 23.976fps which I want to convert to MPEG to burn to DVD. I can play either PAL or NTSC. I gather that 23.976 is NTSC, so probably NTSC would be cleaner.
I've made a few DVDs using PAL AVIs, using HCenc via an AVS script.
However, when I try this script:
AVISource("226.avi").FastBilinearResize (720, 480)
HCenc complains:
"Warning: frame rate not DVD compliant; resolution not DVD compliant."
I guess that I need to convert the frame rate to 29.97.
I've found several Aviscript functions concerning framerate, but am not sure which to use.
(I don't understand however why it complains about resolution, 720x480 should be NTSC; and I also tried 720x576, PAL, with the same result, but I can revisit that after framerate is fixed if it's still a problem.)
Can anyone advise the AVS script to make this work?
23.976 is a compliant framerate, so long as 2:3 pulldown is applied before authoring.
I haven't used HCEnc, so I'm not sure what it is complaining about. Perhaps the framerate isn't 23.976, or perhaps some other setting is conflicting.
Try getting FitCD to create a basic script for you, and try that instead.Read my blog here.
Hi-
I've never heard of FastBilinearResize. If it exists, maybe you have to load a .dll. Not sure. So, I suspect it's not being used, which would account for the error message. Bilinear is crappy anyway. Try:
AVISource("226.avi").LanczosResize (720, 480)
Or some BicubicResize. Much better resizers. -
You also understand that a direct resizing from 576 x 320 to 720 x 480 will give you a distorted output ? You should actually be resizing to 720 x 368, then adding borders to 480, if you want 4:3 letterboxed.
Try this instead, for a 4:3 letterboxed output
Lanczos4Resize(720,368,3,0,570,320)
AddBorders(0,56,0,56)Read my blog here.
I do have the dlls; it may not be the best, but it certainly works, I've done several files using it, and I can use the avs with Virtualdub.Originally Posted by manono
-- I found an "advanced" setting in HCEnc to apply 3:2 pulldown -- no warnings now.Originally Posted by guns1inger
Thanks. (HCEnc seems to have everything, except documentation.)
I'll check out various resize functions later. -
Oh, so it does exist? Learn something every day. Glad you got it going OK.
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 18:36 -
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 13:27 -
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 19:56 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 11:41 -
converting 25fps to 23.976fps
By pannivas in forum AudioReplies: 1Last Post: 3rd Aug 2007, 17:49
