I'd like to do some simple animation with Vegas. For example, picture
a map of the US. I'd like to have a line start on the west coast and
move to the east continually growing in length, that is in the fine
frame the line extends all the way from coast to coast.
Similarly, I might want a cartoon automobile just moving from coast
to coast. What tools do I need to do this?
Results 1 to 9 of 9
Moving the automobile is a simple matter of getting a still, masking it and keyframing the movement. You can either move the car across the map, or the map under the cap. Either way, the Pan and Crop tool is what you need.
Doing the line is best done by getting two versions of the map, one with the line and one without, then doing some form of masked reveal to show the line progressing.Read my blog here.
One way is to buy the Heroglyph plug-in. One of the tutorials that comes with it does this exact thing - easiest way I've found yet to do it. www.heroglyph.de
or you can also follow this thread with an explanation how to do it with just vegas ( creating two maps ) http://www.dmnforums.com/cgi-bin/displaywwugpost.fcgi?forum=sonic-foundry_vegas&post=0...0607003429.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
On one part of the thread, someone mentions (Tom Baldwin) a tutorial at <http://www.bb-video.net>, but that is a bad link.
Here's an idea that may solve my problem. Instead of doing the animation, I can do something like a speeded up sequence. I draw the line going across the map, and you see my hand doing it, but the rate is speeded up. This has appeal, since I'd like this to be fairly comedic. Part of the comedic effect can be erasing and backing up.
For that, I would like to probably know how one can say removed every other frame or every third frame in some automatic procedured? -
At powerpoint, under slide show, pick your animation scheme, and construct your show.
To convert that to video, you can try either of these :
1. Play the power point and use Camstudio to record it as video.
2. Do a web search of "power point animation to avi", and try out those applications from the search result. -
Powerpoint is a very poor substitute for a video tool. Throw in the fact you have to use screen capture tools to get output, and you have a recipe for poor quality junk.
See my response to one of your other posts for methods to do this in Vegas
https://forum.videohelp.com/viewtopic.php?t=306395Read my blog here.
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 08:23 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Sony Vegas Users? Simple editing question...
By jnaizer in forum EditingReplies: 12Last Post: 25th Oct 2008, 16:07 -
vegas 5 animation
By gomez1 in forum Newbie / General discussionsReplies: 12Last Post: 15th May 2007, 21:27
