Some other tool, preferably straightforward and free, that turns VOBs back into their constituent MPEG files. (*) A couple commenters in the Tools Review section for VOB2MPEG stated a preference for version 1, over version 2. My impression was that version 1 did not require MS Net Framework. I tried to invoke version 1.1, since it seems to be directly runnable, without a formal installation. There was an error mentioning the lack of file MSCOREE.DLL. In looking for this on the internet, I found some messages to the effect that this dll file alone won't solve the problem, if one is seeing that error; instead, the whole Net Framework needs to be installed. So, I'm wondering what other tools there may be in this category, that don't require extra MS bloatware overhead.
This is edging into a separate question, but I have also resisted installing some things (into W2K SP4) -- such as Net Framework, WM-10, or Direct X 9.0c Runtime -- because I don't trust MS as far as I can throw them. I don't want to mess with anything that might introduce more security issues, DRM, "phone-home" behavior, or things of that nature. A touch of paranoia, or just prudent caution ?
(* I think I may have done this a couple times -- unintentionally -- using some part of the Nero 6 Ultra suite. NeroVision ? Nero Recode ? But I don't know if this produces good quality MPEG files, or is otherwise a desirable method.)
There are several tools that can rip a DVD to MPEG:
DVDDecrypter(free, also built-in ripping)
Smartripper(free, also built-in ripping)
Rejig(free)
TMPGEnc DVD Author(DVD to one MPG file, only one audio audio track)
VOBEdit(free)
VOB2MPG (DVD to one MPG file, FREE and VERY VERY VERY VERY EASY TO USE!!!)
And probably a few more. This guide may assist you: https://forum.videohelp.com/viewtopic.php?t=224833 -
Sorry, Seeker47, I inadvertently removed your post:
redwudz wrote:
There are several tools that can rip a DVD to MPEG:Thanks for the varied suggestions. I already had several of these, such as SmartRipper, which was quite good in its day and I wondered if anyone still used it for something. (But probably not on some latter day DVDs that have the sort of junk on 'em for which you need Fab Decrypter.)
Regarding VOB2MPG, all versions apparently require Net Framework, and no one seems to have picked up on my query about whether Net Framework is one of those MS things that has security, DRM, or other negative implications.
If you want to get away from .net, DVD Decrypter is a good option, but it does take a few more steps. -
Originally Posted by redwudz
vob2mpg
By peebee44 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Dec 2011, 15:02 -
a good alternative to imgburn
By marlo in forum Authoring (DVD)Replies: 5Last Post: 11th Mar 2011, 11:59 -
Premiere RGB exports produce bad frames - is YV12 a good alternative?
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 17:02 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Where to get vob2mpg v2
By freq in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Nov 2009, 11:47
