Would it be possible for future versions of ffmpegX to include support for .eyetv, the file type that Elgato's EyeTV 2 records into? I want to re-encode my EyeTV recordings into H.264, but the built-in encoder is terrible! It takes about 3 days to encode a standard movie!
Thanks!
fromeout11
(1.83 ghz iMac Core Duo, 1.5 gb RAM)
Is there any method of converting an EYETV 2 file yet? Are they already an MPEG2 file as Toast recognises it as?
EDIT: I've just discovered that the EYETV 2 file is actually a package.
In finder if you right click (or option click) and select show package contents you'll see the MPEG2 file.
You can then simply drag it into FFMPEGX and convert to your hearts content.
Hauppauge HDPVR w/ EyeTV
By xc5000 in forum Capturing and VCRReplies: 1Last Post: 18th Nov 2011, 10:22 -
EyeTV 3.0.4 HD Export Problems
By mattr in forum DVB / IPTVReplies: 0Last Post: 12th Jan 2009, 04:40 -
EyeTV to DVD with subs and all languages
By Nikki in forum MacReplies: 2Last Post: 1st Jun 2008, 11:51 -
Converting EyeTV MPEG file
By lkearl in forum ffmpegX general discussionReplies: 8Last Post: 7th Feb 2008, 10:58 -
EyeTV EPG Help Required
By mattr in forum DVB / IPTVReplies: 0Last Post: 30th Dec 2007, 02:28
