I am using DVDLab Pro 2.0 to compile 6 svcd to one dvd. but it aborted(failed).
here is the log:
*** DVDLAB2 Verification Log ***
8 - 6 - 2006 -- 20:24:51
* VMG Verification *
Number of VTS - 1
Number of Menus: 1
Menu 01 - Type - Dummy
Number of imported VTS: 0
* VTS Verification *
<<< VTS Number 1 >>>
Number of Titles: 6
Title 01 - Type - ES or PES
Segment 1, Video File C:\converted\zhangba\01.mpv
Frame Size: 480 X 480
Frame Rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
Aspect Ratio: 43 [43--4:3, 169--16:9]
MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2]
Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4]
GOP 1, size - 147270
GOP 2, size - 169643
GOP 3, size - 161439
Segment 1, Audio File C:\converted\zhangba\01.mp2
Audio type: MPEG, Channel: 2, Sampling: 48000, Bitrate: 192000
Segment 1, Subtitle File : None
Title 02 - Type - ES or PES
Segment 1, Video File C:\converted\zhangba\02.mpv
GOP 1, size - 182302
GOP 2, size - 210343
GOP 3, size - 261700
Segment 1, Audio File C:\converted\zhangba\02.mp2
Title 03 - Type - ES or PES
Segment 1, Video File C:\converted\zhangba\03.mpv
GOP 1, size - 168920
GOP 2, size - 190441
GOP 3, size - 116375
Segment 1, Audio File C:\converted\zhangba\03.mp2
Title 04 - Type - ES or PES
Segment 1, Video File C:\converted\zhangba\04.mpv
GOP 1, size - 176768
GOP 2, size - 216130
GOP 3, size - 246480
Segment 1, Audio File C:\converted\zhangba\04.mp2
Title 05 - Type - ES or PES
Segment 1, Video File C:\converted\zhangba\05.mpv
GOP 1, size - 129155
GOP 2, size - 152203
GOP 3, size - 148728
Segment 1, Audio File C:\converted\zhangba\05.mp2
Title 06 - Type - ES or PES
Segment 1, Video File C:\converted\zhangba\06.mpv
GOP 1, size - 174515
GOP 2, size - 193906
GOP 3, size - 83498
Segment 1, Audio File C:\converted\zhangba\06.mp2
Number of Menus: 2
Menu 02 - Type - Still
nMenu cell count - 1
Menu Image File C:\Temp\55324632_tmp1.bmp
Picture size - 720 x 480
Menu Audio File - None
Menu Sub-Picture File C:\Temp\55324632_tmpsub1.bmp
* Status Messages *
Start building Video Title Set ( VTS ) ... - 2001
Title - 1
Start building VOB streams - 2210
Muxing elementary streams is in process ... - 2220
Initializing audio packets ... - 3005
Initializing MPEG 1 audio packet ... - 3020
[INFO] - No subtitle stream is provided - 3739
Muxing is in process ... - 2300
Audio packetizing ends - 3025
Creating PGC for the title is in process ... - 2500
Title - 2
Title - 3
Title - 4
Can some1 help me to find what is the problem? Is it something relative to GOP problem?
It seems DVDLAB Pro1.53 run better than new version....
I don't want to reencode the video....... Thanks for any help!![]()
I think you have to reencode the video. 480x480 isn't in the dvd specs. You can do vcd video with just changing the audio to 48khz but svcd has to have the resolution changed to either half d1 352x480 or 720x480 or 704x480 (ntsc). That might be your problem.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
supergoku,
Hi. You may try to use MPEG Video Wizard DVD to make non-standard format DVD. Namely you can export the DVD using SVCD without re-encode. I have try this many times. It seems work fine.
Wish to help you.
ffmpegX mpeg2enc compiling problem
By dubis in forum MacReplies: 5Last Post: 12th Sep 2008, 16:54 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31 -
Compiling a DVD
By LiCal in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 13:31 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 18:39 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 14:58
