Probly a simple question... but lets say I did a 3pass CCE encode, then decided, y'know what I wanna do 5passes. Can I let the 3 passes go ahead and encode... then run it again load the previous .vaf that was created and set it up for 2 more passes to equal 5 or would that equate to only 2passes? Basically.... does the .vaf always keep track of the previous encode information in this case... the third pass, letting the 4th and 5th refine on it?
Closed Thread
Yes you can do what you want. Setting CCE to run 5 passes all at once is no different than running 3 then running another 2. Just make sure the .vaf stays in the output directory.
I think you miss-read his post Adam. He doesn't want to use the vaf for a subsequent encode, he wasn't to add two more passes to an already completed encode. That, I don't believe, is possible.
Read my blog here.
Here's what gunslinger has already said in the other thread... best to keep this all in one.
Now you can battle to the death :PNo. The VAF file contains the analysis data that CCE uses to alocate the video data when encoding. Each pass refines the allocation. Onc an encode finishes, that's it. You can re-use the VAF file in a subsequent encode, so long as nothing else changes, however you cannot use it to add to an existing encode.
Once you complete an encode, that's it. You can re-use the VAF file, but you have to start the encode again if you want 5 passes instead of 3, and the original 3 pass encode is thrown out. CCE will use the VAF file, which saves you one pass. If you note my response to your other post, I believe Adam misunderstood your request.
What's the expected syntax in AvsPmod extra args when running extern player
By kaskaļ in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2011, 13:52 -
More than 2 passes
By marioval in forum Authoring (DVD)Replies: 6Last Post: 15th Mar 2010, 05:59 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33
