Hi guys, I am creating a dvd for a friend to play at a birthday party. I don't have a whole lot of experience with the different audio formats that can be used on dvds. It has to be played on a stand-alone dvd player that I won't be able to test it in first to make sure everything is compatible. I am currently working with a DVD compliant MPEG-2 file with Mpeg Layer 2 audio created in Pinnacle Studio 10. I will then use Adobe Encore DVD 2 to make some custom menus and burn the dvd WITHOUT transcoding my MPEG file again. Is there any reason why this wouldn't play on any type of DVD player or why I would want to go with PCM or AC3 instead? Not that this has much to do with the audio but I will be using Verbatim DVD+R's for the project. Any other tips to make my project compatible with the majority of DVD players would be greatlt appriciated. I am sorry if this has been discussed before, but I didn't find a whole lot about making most compatible DVDs possible using the search. Thanks!
I would use pcm or ac3, http://www.digitalfaq.com/dvdguides/authorburn/intro.htm#audio
Most Compatible Format for Websites
By ofpeb in forum Video Streaming DownloadingReplies: 11Last Post: 5th Dec 2011, 10:50 -
MP4 with 2.0 audio: the only HD format compatible with BOTH ps3/xbox360?
By Randm in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 13:09 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
.asf to MAC compatible format??
By Keaton in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2008, 13:11 -
Which format is most compatible to play on other players?
By csmith in forum DVD & Blu-ray RecordersReplies: 9Last Post: 11th May 2007, 06:32
