Hi all, very new person here, does anyone know why the .avi files i have converted and burnt to DVD using avi2dvd are in black and white and not colour? the .avi are colour prior to converting, i am using Nero 6 to burn to DVD.
Thanks in advance,
Luke.
Hmm... You say you're in the UK? My first guess would be its a ntsc video clip and you're playing back in pal. Shouldn't be a problem normally but it could be. Did you set pal as your output in avi2dvd?
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hi Yoda 313,
I am in the Uk yes, and after reading what you said i checked and i hadent ticked the ntsc to pal box, so i ticked it and converted the file, the only problem i have now is the 40 minute clip is now 4.8GB in size rather then the black and white 1.8-2GB sizes i had before and is too big to put on a DVD so i cannot confirm if this had fixed the problem or has even converted properly, i have read elsewhere about something called DVD shrink 3.2 is this something that could help me or is there a simpler solution in avi2vd?
Thanks for your time on this.
Luke -
Might also try asking about it here:
http://www.trustfm.net/divx/Forum.html -
Dvd shrink takes an already authored dvd and shrinks it down to single layer size. EDIT - yes assuming you have authored the mpeg file into a video_ts folder you can use dvd shrink to compress it to fit a single layer dvd.Originally Posted by luke.2
There are other avi to mpg converters available. divxtodvd is one. Check the tools link on the left.
Thanks very much, used the program you mentioned and it worked quicker and better, thanks very much.
Luke
help please with AVI2DVD
By kayla33 in forum Video ConversionReplies: 5Last Post: 19th Feb 2011, 13:10 -
Avi2dvd
By sportflyer in forum Video ConversionReplies: 4Last Post: 18th Feb 2010, 00:15 -
Avi2dvd help
By morg55 in forum Video ConversionReplies: 3Last Post: 27th Mar 2008, 16:51 -
Avi2DVD
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 13:53 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
