Can anyone provide some input regarding Cinema Craft Encoder settings (v.2.10.02.06)? I'm new to CCE and I can't seem to get any decent results when trying to reduce the size of my Sony Vegas produced mpg files. For example I have a 600mb mpeg2 file of a 10 minute clip and want to reduce the bitrate in cce such that the filesize becomes, let's say half, prior to authoring, so I can fit more on a DVD. I don't want the authoring software to reduce the file, as usually they don't do a very good job in re-encoding. I heard cce is the best for that, but when I tried reducing it using 3-pass vbr, approx. 2.5 kbits/sec, the portions with high motion had lots of macroblocking and blur. I tried the same with autogk and get near perfect results, however the resulting file is an avi,so it's not DVD compliant, so I can't use that. An alternative would be to reduce the file in autogk first and then convert it back to mpg using cce, but then I have to re-encode twice. Not sure what that does to the quality.
PS: I'm frameserving the mpg file from virtualdubmod to cce.
lower the resolution, 325x288 or 352x480 are valid for dvd.
352 x 288 = PAL VCD resolutionOriginally Posted by Baldrick
352 x 480 = NTSC Half-D1
As the OP's in Texas, I'm guessing you meant 352 x 240 for NTSC valid VCD resolution, not PAL's 352 x 288?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Every time you convert to a lossy codec you lose some detail and add some artifacts.
Compressing with autogk first won't help because the process of converting the video to Divx/Xvid consists of decompressing each frame or the source back to an uncompressed state, then compressing with Divx/Xvid. Imagine if autogk compressed the video really well, then decompressed it with no artifacts and with every frame exactly the same as the original source. That would be no different than simply using the original source for your conversion!
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 11:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
