I have another question:
We have several home made movies taken on our Camcorder on VHS HS tapes. Is there a way to convert this and burn them onto DVD? Our DVD player is not a recorder. Our PC DVD burner is LG.
You can send them to store for conversion. In U.S., there are Ritz camera, Circuit City, and .... It runs about $10.00 per tape.
Or
You can buy a DVD recorder, it also serves the purpose of recording TV program like Queen's Birthday Parade. -
Or you can get a capture card for the computer and then author your dvd on the pc and burn the dvd with your burner.
There are tons of choices out there too
Hauppuage pvr 250 and 350 series come highly recommended here. I have the fusion hdtv gold t 3 personally and really like it.
of course the easiest way to get an instant dvd is to buy a settop dvd recorder like singsing mentioned. You hook up your vcr or camcorder to the dvd recorder and pop in a blank dvd recorder. Hit record on the recorder and play on the vcr/camcorder and your done once it finishes playing. Easy and simple. Though if you want fancy menus and more editing options you can copy the dvd from the recorder to the pc and reauthor it.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Agreed.Originally Posted by SingSing
I used to be big into VHS capture using a PC - now it's just so much easier and quicker with a DVD recorder.Regards,
Rob
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
