Hey, I am in a pickle here and was hoping you all could help. I recently purchased an upconverting DVD player, an LG DN191H, and am having some problems.
When I play DVDs with a lot of deep black next to color, Star Wars for example, I get all kinds of large blocky pixels on the screen where the black is. This happens if I am in 480, 720, or 1080. I have the DVD player hooked up through HDMI to my INfocus SP5000 projector. I also have an Xbox hooked up to the projector through component cables, and when I watch the same movies, there is no problem with the blacks at all. I know the Xbox doesn't upconvert, but this still perplexes me.
Have any of you experienced this problem? Is this just a crappy DVD player? Please help me! Thanks.
see if you have a black level adjustment on the LG , i dont think so -- and if so it is a crap player
the INfocus SP5000 is not to bad a projector (at that price), but it is an lcd projector and so will never be super great on blacks anyway, but on that projector, it is not that bad --"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You probably just need to calibrate the TV to the player. Use the THX Optimizer found on all the Star Wars DVDs. It's most likely a contrast/brightness issue.
analog upconverting
By jaybird in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 22:20 -
HD and upconverting over component?
By RoyGBiv-inRI in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Jul 2009, 20:40 -
When upconverting doesn't
By Seeker47 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Feb 2008, 14:34 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 17:42 -
upconverting vhs etc
By victoriabears in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2007, 03:38
