  1. would anyone know of a program where you can put pictures on a dvd and when you show them on the tv screen there is text to say what each picture is, I have used photoDVD which shows names of pictures on my DVD, But a friend who I also sent dvd to said she cant see no writing on her tv screen what the names of the pictures are. I dont really want to use a art program to put names on pictures as this spoils them i think, plus it takes ages, I just need text on them, which will show on all TV screens
    hope someone out there has any ideas on this
    many thanks
    Apr 2004
    Miskatonic U
    Have a look at photoDVD and see if you can alter the position of the text. It sounds like it is outside the safe areas (pretty dumb for a DVD program) and falling into overscan.
    Otherwise, look at something like Memories onTV.
    Read my blog here.
  3. yes i will check this out, but I dont think there is any way of changing where text go, but will also try memories on tv as well
    thanks
  4. Hi I have found out why DVD wont show text on screen using photoDVD on my friends dvd as she never had subtitles on silly mistake.
    also this syncview aligement tool as u suggested looks cool but when I extract audio from movie and add it to syncview aligement tool it says this error
