  1. Hey all!
    I've been using Nerovision for some time, and generally it works ok. Though sometimes when i burn VCD sound gets totally out of sync. Doesent matter if it's one or two cds, it just happends sometimes.
    Anyone knows why?? should i change to another program for burning VCD or?? Is there any better prog just for VCD??
    Cheers for now
    Jan 2006
    Australia
    when you say sometimes, do you mean with the same file?
    nero transcodes everytime it burns and is not good with vbr audio
    try convertXtoDVD
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    try convertXtoDVD
    convertxtodvd will be no good for creating VCDs
    Firstly, I don't know why you'd persist with VCD now that DVD burners, media and settop players are so affordable and offer so many more benefits than VCD, but each to his own, I guess ...
    Nero is pretty ordinary for anything other than burning IMHO, and I wouldn't use it at all in the encoding stage. TMPGEnc is fairly widely renowned as one of the best for VCD encoding. VCDEasy has a similar rep as far as authoring goes. However I used to use Nero for authoring, but turned the transcoding part of it off.
    If in doubt, Google it.
