Hi people,
I have a friend in the US that would like to play his PAL discs in the US.
Can you recommend a decent player that can transcode in real-time, and therefore output NTSC in the US? He only has an NTSC TV set.
He would also like to handle DVD-R media on the player.
I saw some on Amazon but am confused and worried about recommending something that would not work.
'Thank you' for any help you can give me.
I bought a Lite-on 5006 for exactly that reason. Plays PAL disks perfectly.
This is a sweeping generalization but people who bought early PAL to NTSC converting DVD players tell me they couldn't "unsqueeze" PAL widescreen discs. You either needed a widescreen TV or had to put up with a "squeezed" picture. Things may have changed since then.
I have an old Liteon LDV 2002. It converts PAL to NTSC by repeating every 5th frame so the result is a little jerky. But the image is scaled (720x576 -> 720x480) well.
The Philips DVP 642 has smoother video (probably 3:2:3:2:2 pulldown) but scales badly (I think it uses a nearest neighbor filter).
I hear the newer Philips players, like the 5140 and 5960, scale better and are all-around better players:
https://forum.videohelp.com/viewtopic.php?t=301153&postdays=0&postorder=asc&start=0
http://home.wi.rr.com/ntngod/dvp642_vs_dvp5140/
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
playing +R DL discs
By dan101 in forum Authoring (DVD)Replies: 13Last Post: 8th Jun 2009, 01:40 -
Playing Region Free PAL DVD On Soon To Be Hacked Toshiba HD-A2 Player??
By akthmps in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2009, 14:19 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
Region Zero PAL discs
By Musica in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Jun 2008, 10:24
