I am getting an error message when I download a youtube url to Keepit.com. Click and drag URL to Super software. click encode and an error pops up. Need help. Thanks.
What does the error say? SUPER's error messages usually offer suggestions on how to resolve the problem.
That said, I don't think SUPER handles FLV streams directly, but I could be wrong. Also, SUPER can only handle FLV Flash video streams that don't use the VP6 codec or anything other than the default FLV codec.If cameras add ten pounds, why would people want to eat them? -
Here is the error message: An error has occured while encode. The most common possible reasons causig error:
If you do not check "Use DirectShow", you may try to check it on, as you may have a working ActiveX filter installed on your PC that could read the codecs of your input files. Your input source file may not be a valid multimedia clip due to a damanged header, corrputed/segmented data or truncated file. Or maybe your input files has unsupported codecs. Here again, yoy may verify the structure of your input file by double clicking it, the media analysis box opens to display its infor, codecs and other internal data.
Youtube and conversion of 60 FPS videos
By CursedLemon in forum Video ConversionReplies: 3Last Post: 14th Sep 2010, 09:07 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 14:40 -
Youtube HD 1080p settings? Youtube conversion out of sync!
By DoubleJMan in forum Video ConversionReplies: 12Last Post: 5th Jan 2010, 02:04 -
Why won't YouTube convert a video that was downloaded from YouTube?
By brassplyer in forum Video Streaming DownloadingReplies: 0Last Post: 5th Dec 2008, 05:47 -
Youtube: Best settings for YOUTUBE in premiere pro? (encoding)
By vid83 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jun 2007, 19:52
