Hi guys.
Does anyone know how to get the LG RH7800H to play mpegs? Ive just bought this machine and it cost a fortune but it doesnt handle mpeg. I find this hard to believe! I installed the most recent firmware that I could find but still nothing. Does anyone have a solution to this for me? Id be so grateful.
Thanks guys,
donkeyman
Could someone tell me if Im wasting my time posting this question? Should I take the lack of reply to mean that this its just not possible to play MPEG on the LG RH7800H?
Thanks.
I own a RH7521 unit. It playback DivX and DVD/VCD format only. I think the RH7800H is similar except it has a 160gig hard disk.
For MPEG, you need to burn to VCD or author to DVD.
Please refer to the VH DVD player database for detail.
https://www.videohelp.com/dvdplayers.php?DVDnameid=5605&Search=Search -
Hi pchan. I was hoping that someone might have a work around. Like a firmware update or something. Up until now, Ive been forced to convert the mpegs into avi's which is so damn time consuming. Oh well.
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 22:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
8x DL wont play in PS3
By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 15:16 -
mpeg video wizard wont play audio
By acestu in forum EditingReplies: 4Last Post: 25th Aug 2008, 12:49 -
WinDVD7 wont play PAL dvd with mpeg audio correctly ?
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 26th Apr 2008, 15:57
