can anyone here tell me if 320 kb/s is ok for recording at 44100 hz or whats best setting to record from my vhs to my pc through a tv card
Because the source is VHS, 224 should be sufficient. Bear in mind that if you're putting your captured file on DVD you should set it for 48000hz, not 44100.
You can't use mp3 if your going to make a dvd. It has to be wav (pcm), mp2 (mpeg audio layer 2), or ac3 (or dts but you have to have another compatible format like ac3 or wav in order to play it on a tv without a dts receiver since a dts only dvd is out of spec but usually playable - but it will be soundless if played only through a tv since a tv generally doesn't have a dts decoder on board).
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you set it for PCM than it's going to take up considerably more space than 224kbps mp2 or AC3. PCM is uncompressed.
If it's for DVD it must be 48KHz no matter what codec you use.
You can then set it on 224kbps if using the AC3 ACM, OR you can use PCM WAV, which is 1536kbps straight up. It all depends on what you want the outcome to be. If the source is VHS, then I'd go with the first option.If in doubt, Google it.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
