I would like to ask a real basic question.
If you have a mpeg2 video file and convert it to
a cbr 2000kps mpeg2 video file,
will re-encoding it at 4000kps increase the over all size of the video file?
Does this apply to all codecs?
What I'm asking is once infomation is lost it cannot be replaced or does it get replaced with noise and therefore increase the final size of the mpeg2 video file
It will double the size of the file. Yes, it holds for all codecs - audio and video. The encoder will simply pad it out to fill the space.
It is pretty simple. The measure of bitrate, in kbps, is a constant. Doesn't matter if you use Xvid, mpeg or AC3, if the files all have the same length (running time) and bitrate, they will be the same size. That is why you only need one bitrate calculator, regardless of the encoding you are doing.Read my blog here.
Understanding 3D technology
By mbudman in forum Newbie / General discussionsReplies: 37Last Post: 31st Dec 2011, 13:22 -
Picking and understanding Resolutions
By kkiller23 in forum Newbie / General discussionsReplies: 10Last Post: 15th Sep 2010, 02:27 -
Any possible help please, with understanding my MP4 videos
By JohnBarnshaw in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 14:40 -
Help understanding antivirus
By Tbag in forum ComputerReplies: 3Last Post: 25th Oct 2008, 13:06 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 13:54
